replace powertaglink to a Panel server
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • replace powertaglink to a Panel server
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
PowerLogic™ PowerTag
sesa242973_brid
Ensign sesa242973_brid Ensign
Ensign
Posted: ‎2022-10-10 03:28 AM
3011
My customer has a broken PowerTag Link  HD in a panel and wants to replace this for a PAS600.
He can not unpair the old PowerTags and pair this with the PAS600
What is the correct workaround?
BR Geeke Pouw
  • Thumbnail of PowerLogic™ PowerTag
View products (1)
  • Commissioning
  • Legacy Gateways & Energy Servers
  • troubleshooting
sesa242973_brid
Ensign
Posted: ‎2022-10-13 03:54 AM
we found the solution;
More less general procedure for Powertags:
You need first for powertag to lose communication with a gateway (blinking red). You can do this by powering down the gateway for example. Then after 200 (better 300) seconds, powertag starts to blink red fast (once/second), then you need to remove power to the powertag and put it back on, then powertag can be paired to another gateway (blinking fast orange).
Replies 4
Romain_Polette
Kirk
Posted: ‎2022-10-10 03:33 AM
3008
Hello @sesa242973_brid ,
Please describes the symptom for the "broken" PowerTag Link.
Depending on your answer, we may have a solution.
Thanks.
Romain POLETTE
Solution Architect - France Operations
sesa242973_brid
Ensign
Posted: ‎2022-10-10 05:53 AM
2
2997
problem with the power in a demo panel...... they had a small BBQ 😁
now they want to replace i for a PAS600
Romain_Polette
Kirk
Posted: ‎2022-10-10 05:57 AM
2994
In this case, there is no workaround... product must be replaced.
Because you cannot load a configuration file from a PowerTag Link to a Panel Server you will need to restart the commissioning from scratch:
  • Power off / on the PowerTag Sensors to switch them in pairing mode (blinking orange). It means you will need to open / close the breakers associated to the PowerTag Sensor.
  • Restart the PowerTag pairing with the Panel Server
Romain POLETTE
sesa242973_brid
Ensign
