Hi All,
A short question, if the upper client of PAS600 is Resource Advisor, a device model is necessary or PAS600 as a transparent gateway is enough?
If the upper system is a cloud service using ETP like RA, EAA ED, PAS is working in the same way as ComX.
You need to define :
2 possibilities :
As per Guillaume's post, you will need to configure the devices locally to be polled by the Panel Server.
Then the logging profile can be pushed to the PAS via ETP from the "Advisor" (RA in this case) or EPC-Web.
If you do not have access to EPC-Web the RA project team can set the logging for you once notified that the local team has completed the addition of meters to the PAS, connected it to ETP and the values validated between the PAS and the meters display.
Please ensure the normal RA workflow is followed and this info is given to the RA Project manager or SB team you are working with.
See the attached "public" guide for those without access to EPC-Web.
We also have an administrator version for those with access to EPC-Web & RA Gateway management page.
2 possibilities :
It's very clear. Many thanks for your information @sesa64390_bridg @Guillaume_Evrard !
