REST API with PAS
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • REST API with PAS
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
Jun_Escano
Lieutenant JG Jun_Escano Lieutenant JG
Lieutenant JG
Posted: ‎2023-03-06 02:52 AM
1824
REST API with PAS
Hi all,
First of all is compatibility with (REST) API available for Panelserver? Second will there be a similar document as the COMX510 describing the request / access and such? See document
Thank you
 Jun
  • Thumbnail of EcoStruxure Panel Server
View products (1)
  • Commissioning
Szymon_Hochół
Captain Szymon_Hochół Captain
Captain
Posted: ‎2023-03-06 03:46 AM
1821
Hi @Jun_Escano ,
there is no such feature available on Panel Server.
Also, to my knowledge, the API on the Com'X was used only to retrieve the measurement on Custom Webpages that could be created on Com'X webserver. I'm not sure they could be used to share the data with external systems. (Maybe someone can confirm this?)
BR
BenjaminJ
BenjaminJ Cadet
Cadet
Posted: ‎2023-03-06 05:33 AM
Hi All,
The API documented in the attachment was created to enable the custom webpages feature in Com'X.  This is why the document doesn't cover authentication.
Even though it was not originally intended (or prohibited), there are some applications that are using the Com'X API remotely.  This was not so difficult given available documentation and observing the web application behavior as a reference.
I would suggest caution taking a similar approach with existing API in the panel server.  The API could change in future versions.
Best Regards,
Ben
