How to access a Com'X200 with firmware version 2.2.1
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • How to access a Com'X200 with firmware version 2.2.1
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
solutions_iems-
Lt. Commander solutions_iems-
Lt. Commander
Posted: ‎2024-03-22 08:29 AM
1965
I have a customer with a Com'X200 server running firmware version 2.2.1 and I have been asked to change the FTP server settings. I have tried to connect to it using several different web browsers but none support the old level of security offered by firmware 2.2.1.
Example from Chrome;
"This site can't provide a secure connection, 192.168.1.232 uses an unsupported protocol, ERR_SSL_VERSION_OR_CIPHER_MISMATCH"
I have tried an old laptop that runs Internet Explorer but still have the same issue.
Do you have any suggestions?
  • Legacy Gateways & Energy Servers
Romain_Polette
Kirk
Posted: ‎2024-03-22 09:06 AM . Last Modified: ‎2024-03-22 09:16 AM
1959
Hello @solutions_iems- ,
Please check these topics:
https://community.se.com/t5/Gateways-and-Energy-Servers/SSL-protocol-error-with-EBX510-with-google-C...
https://community.se.com/t5/Gateways-and-Energy-Servers/Log-into-Com-X-webserver/m-p/386609
Try to upgrade your Com'X with USB:
https://www.se.com/ch/fr/download/document/ComX200_v3.5.54/
Or maybe upgrade through EPC:
https://www.se.com/fr/fr/download/document/Ecoreach_Installer/
But Com'X 200 is old (cipher suites not updated), and I'm not sure modern browser will allow connection, even with the most recent FW (year 2019).
Romain POLETTE
Solution Architect - France Operations
Guillaume_Evrard
Captain
Posted: ‎2024-03-24 09:52 PM
Yes it should work with the latest FW of ComX200 with Chrome, you can try also with a old PC running an old version of IE....
Upgrade using USB is a good recommendation.
Kind Regards,
Replies 7
Romain_Polette
Kirk
1960
Romain POLETTE
Romain_Polette
Kirk
Posted: ‎2024-03-22 09:24 AM
1958
This seems working with Com'X200 V3.5.54 + MS Edge or Chrome
Romain POLETTE
Guillaume_Evrard
Captain
Kind Regards,
solutions_iems-
Lt. Commander
Posted: ‎2024-03-26 06:29 AM
Hi Romain
I have tried updating the firmware to version 3.5.54 several times using the USB method but it hasn't worked, or if it has, version 3.5.54 is no longer accepted by the current versions of Chrome, Edge, etc.
Any other suggestions?
Thank you.
Iain
Romain_Polette
Kirk
Posted: ‎2024-04-02 12:12 AM
1799
Hi @solutions_iems- ,
Any progress on your side ?
Com'X200 v3.5.54 + Chrome is working for me. Maybe update through USB did not work.
Other solution could be to connect the Com'X 200 to EcoStruxure Power Commission and try to upgrade:
Romain POLETTE
solutions_iems-
Lt. Commander
Posted: ‎2024-04-02 08:35 AM . Last Modified: ‎2024-04-02 08:35 AM
1781
Hi Romain
I have tried adding the Com'X200 to Power Commission but the software tool cannot discover the IP address/add the IP address manually, nor show Firmware details - no device found!
It looks like it is the end for this energy server.
Iain
Guillaume_Evrard
Captain
Posted: ‎2024-04-02 10:04 PM
Upgrade using USB might be tricky, are you sure of the procedure followed ?
Kind Regards
