ETL For PAS800 Data Log Export CSV File
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • ETL For PAS800 Data Log Export CSV File
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
JamesChen
Crewman JamesChen
Crewman
Posted: ‎2024-05-08 03:15 AM
2487
Hello All
When I test ETL with the PAS800 data log export CSV file.
It's not working
Because the export CSV format different to data publication via SFTP
  • troubleshooting
UdhayakumarAK
Commander UdhayakumarAK Commander
Commander
Posted: ‎2024-05-28 11:05 PM . Last Modified: ‎2024-05-28 11:06 PM
Hi @JamesChen
Local export csv file format is meant for local analysis purpose (like excel report/data validation/.. ). SFTP export csv file format is more for data sharing for another systems/SCADA. PAS800 local export csv file format is slightly different than the SFTP export csv format. So, there is a predefined ETL extract job for SFTP csv files which does it for PME data upload and other Schneider applications but in case if you want to use local export file still it is possible. This needs an ETL expert advice it depends on your requirement.
FYI, i think there is no support for new requirement on ETL. This will be a requirement, maybe you can elaborate your requirement and purpose, will check and comment on that.
Regards
Udhayakumar A K
ESXP System Support Expert
  • Thumbnail of EcoStruxure Panel Server Advanced
View products (1)
Replies 9
Charles_Murison
Picard Charles_Murison Picard
Posted: ‎2024-05-10 08:55 AM
2450
Hello @JamesChen ,
Have you applied the hotfix for ETL from https://www.se.com/in/en/faqs/FAQ000259575/ ? If so and did not work, did you try the workaround?
Charles
UdhayakumarAK
Commander
Posted: ‎2024-05-27 11:01 PM
2371
Hello @JamesChen
Hope Charles message helped you out. If you are using PAS (panel server) with older Firmware i.e lesser than 1.6.0 the default ETL - EGX extract task should work. In case if you are using latest Firmware version or higher than 1.5.1 then you should use the ETL with hotfix version as mentioned in the FAQ link. Suggestion is to use to the latest Firmware version of panel server and the ETL with hotfix.
Regards
Udhayakumar A K
JamesChen
Crewman JamesChen
Crewman
Posted: ‎2024-05-28 12:00 AM
Does anyone knows how to use ETL import the PAS800's CSV file to PME?
p.s. the CSV file export from PAS800's WEB page ,  not use SFTP publish.
JamesChen
Crewman JamesChen
Crewman
Posted: ‎2024-05-28 12:10 AM
Hi  @Charles_Murison
This way only apply for PAS800 publish csv file via SFTP.
Not for downloading directly from PAS800 Web page.
JamesChen
Crewman JamesChen
Crewman
Posted: ‎2024-05-28 12:11 AM
Hi  @UdhayakumarAK
ETL only apply for PAS800 publish csv file via SFTP.
UdhayakumarAK
Commander
Hi @JamesChen
Regards
Udhayakumar A K
View products (1)
JamesChen
Crewman JamesChen
Crewman
Posted: ‎2024-05-29 12:08 AM
2329
@UdhayakumarAK
We install the PAS800 for power meter recod in different sites without Internet access.
Monthly we manualy download the energy data from PAS800.
And all so the data needs to be imported into PME for energy Management.
Maybe can add a new function button to PAS800 "Download CSV for ETL"
Thanks for your support
Charles_Murison
Posted: ‎2024-05-29 11:38 AM
2308
Hello @JamesChen ,
I do not know the PAS devices well so I cannot speak to exactly how the downloaded data is formatted. If you have this data and doing manual steps already, perhaps there could be 1 additional step to format the data in a way that the existing ETL extract tasks can process the file. I believe there are a few different CSV formats ETL tool supports.
Charles
JamesChen
Crewman JamesChen
Crewman
Posted: ‎2024-05-29 06:36 PM
Hi @Charles_Murison
How to format the data in oder to importing to PME by ETL.
I hope Schneider teams can provide steps via docs or videos.
data-export_from PAS800.zip
