Gateways and Energy Servers
User | Count |
82 | |
46 | |
29 | |
28 |
The latest firmware for the Com'X 200 is 3.5.54. And, no, the firmware for the Com'X 210 will not work on the Com'X 200.
Randi
Thanks Randi
Hi Randi,
yet where is the source to download latest firmwares for Com'X 200 & Com'X 510?
I mean not knowing which version is the latest?
To find the latest firmware for the Com'X, go to www.se.com and type the product name in the search bar. From there, you can select the product and then select the firmware.
Hi Randi,
I was able to find product page here: https://www.se.com/ww/en/product/EBX200/comx-200---data-logger/
But there is no link to download any firmware. Maybe I'm missing something?
I'm not sure how you got there. But, I typed "Com'X 200" in the search bar. That brought up a drop down list where I selected "See more results". Then I selected "Documents and Software" in the "Show results for" box on the left. Then in the "filter by" ... "By Document Type" I selected "Firmware - Released", which brought up this page.https://www.se.com/us/en/search/Com'x%20200?filters=CAT_PRD_DOC&ddcDocType=1555893 ... the latest firmware is at the top of the list.
I hope this helps.
Randi
Thanks, I was able to locate the latest firmware, not exactly the way you described, but I found it. 👍
I downloaded the latest ComX510 Firmware v 6.5.5.from www.se.com and received the following error - please advise:
Just curious... would you click on the "About" link on the top right hand corner and see what the version number is?
Would you turn off SNTP and then try the firmware upgrade again?
Randi
With SNTP turned off it upgrade to 6.5.5 version
Thanks for this information. We will try to address that issue.
