Com'X configuration - adding Panel Server as an ethernet device
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Com'X configuration - adding Panel Server as an ethernet device
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
swil
Commander swil
Commander
Posted: ‎2022-10-23 03:32 PM
1969
Is it possible to add a PAS600 (or PAS800) as a downstream ethernet device in a Com'X 510 / Com'X 210 Configuration?
Although the Panel server is not an ethernet device in the Com'X, could the "LINK150" device type be checked to add a Panel Server as a downstream ethernet device. From there would it be possible to add panel server connected serial devices to the Com'X configuration? (where local ID matches  slave id in the Panel server config).
  • Legacy Gateways & Energy Servers
Randi_Dolan
Commander
Posted: ‎2022-10-24 06:46 AM
1923
The Com'X backend treats all Gateways the same.  The only differences are cosmetic in the UI (Picture and name).  So, you could pick any Gateway in the Com'X to define the Panel Server and it will work.
Replies 4
Olivier_GARAULT
Lieutenant JG Olivier_GARAULT Lieutenant JG
Lieutenant JG
Posted: ‎2022-10-24 04:10 AM . Last Modified: ‎2022-10-24 04:13 AM
1940
Bonjour,
je viens de faire le test en installant un PAS600 entre un PM5111 (SL) et une Com'X510.
Cela fonctionne très bien.
Il faut déclarer un Link150 dans la Com'X.
Et couper le câble RJ45 sous la Link150 pour le raccordement sur le bornier SL du PAS600...
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2022-10-24 05:36 AM
1931
I complete the answer from Olivier by my own test made several month ago (not the last version of Firmware for Panel Server)
The Panel Server was defined  in the list of child gateways of  Com'X as a PowerTagLink.
With this definition, the Com' X was able to gather measurments of the Modbus SL products (such as iEM meter)  and SE Wireless products (such as PowerTag)
refer to the attached video for demo.
BR
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
Randi_Dolan
Commander
1924
swil
Commander swil
Commander
Posted: ‎2022-10-24 07:39 PM
Thanks for the replies everyone.
It's good to have that answered.
