Device type - IFM Module for Breakers - Com'X and Panel Server
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Device type - IFM Module for Breakers - Com'X and Panel Server
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
swil
Commander swil
Commander
Posted: ‎2022-10-23 06:42 PM
1431
Looking at https://www.se.com/ww/en/faqs/FA285178/
, it appears that there is several types of IFM devices for similarly named breaker models.
Regarding device type selection in Schneider gateways (Com'X / PAS server):
1. In a Com'X, Is a Compact NS is an A/E/H/P com'x model type selected for NSX breakers with Micrologic A/E/H/P trip units?
2. Is there a similar file to the above link detailing supported devices for Ecostruxure Panel Servers (e.g. PAS600 / PAS800)? If so, please provide it.
  • Legacy Gateways & Energy Servers
Romain_Polette
Kirk
Posted: ‎2022-10-24 12:02 AM
1406
Hello @swil ,
FA285178 is not up to date. Better look at the matrix file delivered with the Com'X FW package.
Compact NS has not the same Trip Units as Compact NSX.
If you integrate a Compact NSX please select:
  • Compact NSX A IFE or Compact NSX E IFE if connected through Ethernet
  • Compact NSX A or E if connected through Modbus Serial
Compact NS is sharing the same Micrologic trip units as MasterPact. Try to declare your Compact NS as Masterpact A/P/E/H device type.
For the Panel Server, the list of compatible devices is described on the release notes:
https://www.productinfo.schneider-electric.com/ecostruxurepanelserverrn/doca0178-ecostruxure-panel-s...
Romain POLETTE
Solution Architect - France Operations
Thierry_Baudard
Commander Thierry_Baudard Commander
Commander
Posted: ‎2022-10-24 01:01 AM
Hello swill
As you mention in your post, there are two generation of IFM gateway (gen1: TRV00210 and gen2: LV434000)
hereunder the answer to the Question2 of your post about compatibility of IFM with Panel Server.
Even if the  two generation of IFM  are supported by the Panel Server , You must check that the association of IFM+ the downstream circuit breaker is supported (not only the IFM interface!)
To do this, please refer to the the release note of the Panel Server (PAS600 : ref DOCA0178EN-05 / PAS800: ref DOCA0248EN-02) § Supported devices/Modbus serial Devices
Note also that  release note are updated for each new fw version... so  take care to use the last one
BR
Thierry BAUDARD
EcoStruxure Power- Technical Support Expert for Softwares & Solutions
