Posted: 2020-07-02 02:28 PM . Last Modified: 2024-04-09 04:11 AM
Can I connect Spot Fluid Sensor (NBES0301) with Netbotz 150 and then connect it to the Netbotz 200?
The Netbotz 150 support fluid detection sensors, but, the netbotz 200 doesn't support Spot Fluid Sensor (NBES0301).
(CID:99157554)
Hi Aaron,
As far as I know, Netbotz 200 appliance does not support Spot Fluid Sensor.
From the Manual:
NetBotz Rack Monitor 200 is a central hardware appliance for an APC environmental monitoring and control system. The rack-mountable NetBotz 200 includes six sensor ports for connecting temperature and humidity sensors, door switch sensors, and third-party dry contact sensors. Using other ports on the NetBotz 200, you can connect up to eight temperature and humidity sensors with digital display. To expand your system, you can connect up to twelve NetBotz Rack Sensor Pod 150s, which include six sensor ports each.
The following options are available for the NetBotz 200.
• NetBotz Rack Sensor Pod 150 (NBPD0150)
• Temperature Sensor with Digital Display (AP9520T)
• Temperature/Humidity Sensor with Digital Display (AP9520TH)
• Temperature Sensor (AP9335T)
• Temperature/Humidity Sensor (AP9335TH)
• NetBotz Door Switch Sensor for APC Racks (NBES0303)
• NetBotz Door Switch Sensor for Rooms or Third Party Racks (NBES0302)
• NetBotz Dry Contact Cable (NBES0304)
• Alarm Beacon (AP9324)
Please refer the manual for more info:
http://www.apcmedia.com/salestools/AKAR-78QU5F/AKAR-78QU5F_R1_EN.pdf?sdirect=true
I suggest you to choose any of other Netbotz families such as Netbotz 355, Netbotz 450 and Netbotz 550 which can support Spot Fluid Sensor with the Sensor Pod.
I hope this helps.
Bala
(CID:99157564)
That should work with no problem, these are all supported
Regards
Aaron
(CID:99157556)
The sensor pod 150 supports the NetBotz 200 but the flow sensor spot NBES0301 does not support this family of netbotz , so this sensor will not be recognized in this connection
(CID:99157613)
Hi Aaron,
From the Manual:
I hope this helps.
Bala
(CID:99157564)
Posted: 2020-07-02 02:28 PM . Last Modified: 2023-10-31 11:23 PM
