Posted: 2020-07-02 02:29 PM . Last Modified: 2024-04-09 04:11 AM
We do not have VMware ESXi Host for installing the DCO. We have got Hyper V Windows 2012. Can we install DCO on Hyper V? Is it officially recommended?
Bala
(CID:99157584)
Hi Balaraman,
Personally I do not have experience and as such we do not recommend a virtual environment in favour of another.
In general if the requirements are met it should be fine to do the installation in a virtual environment.
In the above I assume we are talking about a smaller/basic single node setup.
The requirements can be found here: System Requirements
/Søren
(CID:99157678)
Posted: 2020-07-02 02:29 PM . Last Modified: 2023-10-31 10:19 PM
