Posted: 2020-07-05 09:20 PM . Last Modified: 2024-04-03 12:51 AM
(CID:147202028)
请问在NBRK0750添加NBPD0165添加不上,我已经吧0750固件升级5.1.0
(CID:147202308)
Hi zhang,
Please post your questions in English so that anyone can understand you. Otherwise you can contact 400-810-1315 hotline in China.
As for your questions, how did you connect the pod 165 o the 750? Please connect it to the switch port of the 750 and see if the camera is powered correctly. It should get a DHCP ip address from the bot 750.
(CID:147784297)
thank you. how to add nbrk0750 to DCE?
(CID:148343653)
i lack DDF file
(CID:148343656)
Posted: 2020-07-05 09:20 PM . Last Modified: 2023-10-22 09:32 PM
