Posted: 2020-07-03 09:01 AM . Last Modified: 2024-04-08 03:40 AM
I have updated from DCO 7.4 to 8.0.2. I have a mobile scanning device (Motorola Symbol N410), have downloaded and installed required files via Wifi. At the login screen on the device Local Mode is greyed out, not allowing me to log in: "Network not available"
Whether port 80 or 443
Installed version:
StruxureWareDataCenterOperationMobile-8.0.2.cab
NETCFv35.wm.armv4i.cab
sqlce.ppc.wce5.armv4i.cab
Everything worked without problems with the "old" Mobile Version and DCO 7.4.
Any Ideas?
(CID:110007978)
Posted: 2020-07-03 09:02 AM . Last Modified: 2024-04-08 03:40 AM
Hi Markus,
Try with disabling the 'Redirect HTTP to HTTPS' feature of the DCO. It can be done via server Webmin interface, as illustrated go to StruxureWare DC Operation > Setup (1) > "uncheck" the Redirect HTTP to HTTPS option (2), and the push the "Setup" (3).
Kind regards
(CID:110007996)
Hi Markus,
Kind regards
(CID:110007996)
Thank you very much, it work now
(CID:110008004)
You are welcome, Markus. Kind regards
(CID:110008006)
Posted: 2020-07-03 09:02 AM . Last Modified: 2023-10-22 04:22 AM
