Posted: 2020-07-05 11:42 PM . Last Modified: 2024-04-03 12:03 AM
Hello community,
Your help please... I have my production server 8.2.7 connected to a DCE using external systems and the DCE configuration, also, it´s connected to a RFCode server using special connector downloaded from community site and using ETL conversion, I´m trying to upgrade this one using a second server with DCO 8.3.2 but I can´t found the following options under de "Struxureware DC Operation" menu:
Is it normal in this new version? Can you guide me on how can I create a backup in the 8.3.2?
Thank you.
Best regards,
Erlinson Bravo G.
(CID:152077664)
Hello Erlinson Bravo Garcia,
Those options can now be found within the Data Center Operation web interface (NOT webmin) under the Administration menu and the gear icon in the upper-right.
Cory
(CID:152077671)
Cory
(CID:152077671)
Posted: 2020-07-05 11:43 PM . Last Modified: 2024-04-03 12:03 AM
Hello Cory McDonald,
Thank you very much, you´re right!
Options located.
Best regards,
Erlinson Bravo G.
(CID:152077699)
Posted: 2020-07-05 11:43 PM . Last Modified: 2023-10-22 04:20 AM
