Posted: β2020-07-03 12:56 PM . Last Modified: β2024-04-08 01:47 AM
(CID:111415671)
Hi Bill,
The SNMP V3 phrases are based upon user name and password for the appliance itself.
Once you've created one and their password, go to SNMP version 3 configuration and select that user and add him:
It's just that simple.
(CID:111415678)
Steve;
I have two unique phrases for snmpv3. Where do the two of them go? I could put one of them under the user password slot, but that still leaves the second.
(CID:111938161)
Posted: β2020-07-03 12:57 PM . Last Modified: β2024-04-08 01:47 AM
Hi Bill,
In NetBotz, there is only the one password / passphrase. If you're using for instance MD5 and DES, both protocols would need to use the same passphrase. I've configured and tested this in a free version off iReasoning and I am able to get results:
Here I use the "snmp_v3_user" for user name and "my_long_v3_SNMP_password" for both passphrases.
(CID:111938158)
Posted: β2020-07-03 12:57 PM . Last Modified: β2023-10-22 04:19 AM
