What is the Serial Terminal Connection Parameters for NetBotz Appliances
  • EcoStruxure IT forum
  • What is the Serial Terminal Connection Parameters for NetBotz Appliances
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 07:03 AM . Last Modified: ‎2024-04-10 01:48 AM
683
I need to connect serially to my Netbotz device. What is the parameters to be used?
(CID:83656816)
  • NetBotz
Terminal emulation (ie. Hyper-Terminal) configuration for communications with NetBotz appliances.
When connecting to a Netbotz appliance via a serial cable, the terminal settings must be set to:
38400 and 8-N-1
NOTE: When connecting to a models 300, 303, 310, or 400, you must use a standard serial cable, such as the kind used to connect a modem to a PC.
NOTE: When connecting to models 320, 420 or 500, you must use a NULL modem cable.
NOTE: When connecting to models 355, 455, 550, 570 or similar version 3 Netbotz, you must use a USB A-B cable.
NOTE: When connecting to a NetBotz Central, you must use a NULL modem cable.
(CID:83656819)
Posted: ‎2020-07-02 07:04 AM . Last Modified: ‎2023-10-31 11:43 PM
