Posted: 2020-07-02 07:04 AM . Last Modified: 2024-04-10 01:48 AM
I have misspelled a virtual sensor in my StruxureWare Data Center Expert configuration. Can this somehow be changed?
(CID:83656821)
Although Virtual sensors can be renamed in StruxureWare Data Center Expert 7.2, the name does not always get changed in other views or in the web API. It is suggested that the names is not changed.
(CID:83656823)
Posted: 2020-07-02 07:04 AM . Last Modified: 2024-04-10 01:47 AM
I've recently upgraded to 7.4.3 and renaming sensors still seems to be a problem. Is there a fix for this yet?
I've confirmed sensors are named correctly on my Netbotz and virtual sensors are named correctly in DCE. When I pull reports or try to create new/edit virtual sensors, the old/incorrect naming still shows up.
(CID:120129266)
To change virtual sensor name, open up Virtual Sensors Window, and search for that sensor. Right lick and Edit virtual sensor name
(CID:93193626)
Posted: 2020-07-02 07:04 AM . Last Modified: 2023-10-31 11:02 PM
