Posted: β2020-07-04 02:57 AM . Last Modified: β2024-04-05 03:40 AM
In "view device sensors" for the comet it shows a temperature. When I pull up "generate sensor history report", the temperature history isn't available. How can this feature be enabled?
(CID:126881685)
Hi Jan,
There won't be a snapshot report for temperature as those are static reports. You should be able to create a custom report though as temperature is available:
Once you choose this report, you can choose a data range or time range, you can choose the devices and device groups, then you choose the specific sensors:
You would also choose graph, summary, or table in the upper right:
It should be just that simple. There is nothing to be enabled in the system, it should just work. If for some reason the temperature sensor is not seen by the system as a temperature or maybe if you've used a supplemental OID, you may want to check under something like "Other Numeric":
K-base document FA301697 may be helpful if you're not sure how to run the report as well.
(CID:126881695)
Hi Jan,
(CID:126881695)
Posted: β2020-07-04 02:57 AM . Last Modified: β2023-10-22 04:16 AM
