Update DCE
  • EcoStruxure IT forum
  • Update DCE
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 12:17 AM . Last Modified: ‎2024-04-05 04:38 AM
1174
Update DCE
Hi
I have DCE 7.2.0
How can i Update latest version ? can i do that ?
(CID:126161731)
1174
Hi Hojjat,
To upgrade to the latest version of DCE you will need to reach out to your local tech support. They will be able to validate your support and provide you upgrade links.
Use the link below to determine your local tech support's number for your region:
www.apc.com/support
Kind Regards,
Andrew
(CID:126161749)
Replies 5
1175
Hi Hojjat,
www.apc.com/support
Kind Regards,
Andrew
(CID:126161749)
my country has't official supporter .... what can i do now ???
(CID:126163928)
Hi Hojjat,
If your country is not listed, pick one that is most local.
Kind Regards,
Andrew
(CID:126165142)
Good day
About this question I have the same situation, my costumer have DCE 7.2 with server AP9465 basic, so is necessary for the update version that support local provide upgrade links, there is other option?, for example if upgrade the version that costumer wants is 7.4?, When the software DCE is VM it is done in the same way or is different. Is possible one video where I can watch how to do this procedure of upgrade with the DCE.
kind Regards,
Leonardo Suárez
(CID:135433878)
Posted: ‎2020-07-04 12:18 AM . Last Modified: ‎2023-10-22 04:11 AM
