Posted: β2020-07-04 12:17 AM . Last Modified: β2024-04-05 04:38 AM
Hi
I have DCE 7.2.0
How can i Update latest version ? can i do that ?
(CID:126161731)
Hi Hojjat,
To upgrade to the latest version of DCE you will need to reach out to your local tech support. They will be able to validate your support and provide you upgrade links.
Use the link below to determine your local tech support's number for your region:
Kind Regards,
Andrew
(CID:126161749)
Hi Hojjat,
Kind Regards,
Andrew
(CID:126161749)
my country has't official supporter .... what can i do now ???
(CID:126163928)
Hi Hojjat,
If your country is not listed, pick one that is most local.
Kind Regards,
Andrew
(CID:126165142)
Good day
About this question I have the same situation, my costumer have DCE 7.2 with server AP9465 basic, so is necessary for the update version that support local provide upgrade links, there is other option?, for example if upgrade the version that costumer wants is 7.4?, When the software DCE is VM it is done in the same way or is different. Is possible one video where I can watch how to do this procedure of upgrade with the DCE.
kind Regards,
Leonardo SuΓ‘rez
(CID:135433878)
Posted: β2020-07-04 12:18 AM . Last Modified: β2023-10-22 04:11 AM
