Posted: 2024-04-04 10:18 PM
Hi all,
If the path is deleted in /opt/EcoStruxureITGateway/ and I am trying to reinstall however unable to as its detected the previous install.
Is there a solution to reinstall without wiping the entire OS?
I have tried dnf remove EcoStruxureITGateway etc seem to not able to locate any dependencies.
Posted: 2024-08-22 06:41 PM . Last Modified: 2024-08-22 06:41 PM
Hello @wasabi,
Instructions on doing an uninstall on Linux for the EcoStruxure IT Gateway, you can reference the following community post: https://community.se.com/t5/EcoStruxure-IT-forum/trying-to-install-setup-EcoStruxutreITGateway-for-t...
Cory
Posted: 2024-04-05 11:02 AM
Hi @wasabi
Have you seen this article? Perhaps it will help you.
If that doesn't answer your question, I suggest that you contact support and submit a general support request.
Best,
Jackie
Hello @wasabi,
Cory
