Posted: β2020-07-04 12:19 AM . Last Modified: β2024-04-05 04:37 AM
(CID:126162091)
Hi Thomas Cunningham,
Your problem can be solved more quickly if you share with us several screenshots and describe it in more detail.
With respect.
(CID:126162370)
Hi Thomas (Thomas Cunningham)
Wondering if the issue is resolved, if not could you please add some description, details and possibly screen capture(s) illustrating the issue, thanks.
Kind regards
(CID:126163024)
Posted: β2020-07-04 12:20 AM . Last Modified: β2024-04-05 04:37 AM
Hi Thomas,
Not certain if the issue is related to user login, blocked/locked user (due to mis-typed password attempts)? then user can login (with correct password) at least after 11 minutes, or you might want to log in (as administrator) and "RESET PASSWORD" for your user:
If that's not the case, please feel free to comment and add details, thanks.
Kind regards
(CID:126163509)
Posted: β2020-07-04 12:20 AM . Last Modified: β2023-10-22 04:10 AM
