Unable to access DCE after configuring SSL Server Access
  • Unable to access DCE after configuring SSL Server Access
129
72
Posted: ‎2020-07-05 01:37 PM . Last Modified: ‎2024-04-04 12:27 AM
1117
Hi guys,
Recently I did some configuration at the DCE Server Access by changing its default SSL certificate to our org signed certificate. After the configuration was made, its pop up a notification that said "DCE might log out or reboot".
But nothing happen, neither the DCE logged out nor reboot. Now, I can't access the DCE at all through web or console.
Any advise to rectify this?
Thank you in advance.
(CID:134692519)
Hi Khairul,
Sorry but you'll need to contact tech support directly if you need to log into that server again. A rep will need to assist with access to the server and delete the cert you've added. Especially if it is a chain cert, please see k-base FA225532.
If the server was just deployed, you could also simply redeploy if a VM or restore the server if it is a hardware server.
Steve
(CID:134692601)
Hi Khairul,
Steve
(CID:134692601)
Posted: ‎2020-07-05 01:38 PM . Last Modified: ‎2024-04-04 12:27 AM
Noted. Will escalate this to tech support.
Thanks for the help, Steve.
(CID:134692955)
Posted: ‎2020-07-05 01:38 PM . Last Modified: ‎2023-10-22 04:09 AM
