84388members
353579posts
Unable to access DCE after configuring SSL Server Access
DCIM_Support
Picard
Picard
245
This question was originally posted on DCIM Support by Khairul Amri on 2018-11-01
Hi guys,
Recently I did some configuration at the DCE Server Access by changing its default SSL certificate to our org signed certificate. After the configuration was made, its pop up a notification that said "DCE might log out or reboot".
But nothing happen, neither the DCE logged out nor reboot. Now, I can't access the DCE at all through web or console.
Any advise to rectify this?
Thank you in advance.
(CID:134692519)
DCIM_Support
Picard
Picard
Re: Unable to access DCE after configuring SSL Server Access
This answer was originally posted on DCIM Support by Steven Marchetti on 2018-11-01
Hi Khairul,
Sorry but you'll need to contact tech support directly if you need to log into that server again. A rep will need to assist with access to the server and delete the cert you've added. Especially if it is a chain cert, please see k-base FA225532.
If the server was just deployed, you could also simply redeploy if a VM or restore the server if it is a hardware server.
(CID:134692601)
3 Replies 3
DCIM_Support
Picard
Picard
Hi Khairul,
(CID:134692601)
DCIM_Support
Picard
Picard
This answer was originally posted on DCIM Support by Khairul Amri on 2018-11-02
Noted. Will escalate this to tech support.
Thanks for the help, Steve.
(CID:134692955)
DCIM_Support
Picard
Picard
🔒 Closed
