Posted: 2020-07-05 01:38 PM . Last Modified: 2024-04-04 12:27 AM
Is there any collaboration diagram as to how the Schneider DCIM will integrate with the existing Data Center ?
A High level Diagram showing the DCIM components integrate with various devices in the data center such as generator/crah/crac/racks/pdu.....etc
(CID:134692529)
Posted: 2020-07-05 01:38 PM . Last Modified: 2024-04-04 12:26 AM
Hi Ivin,
With DCE, we can monitor data center equipment such as UPS, PDU, CRAC, CRAH, rack pdu, Netbotz, etc.
More info on DCE: User assistance for StruxureWare Data Center Expert 7.x Home
With DCO, we can model data center(s), integrate it with DCE (as external system) to get device/sensor data into DCO (such as power measurements, temperature/sensor data, alarms, etc.)
More info on DCO: User assistance for StruxureWare Data Center Expert 7.x Home
When/if we should need support for devices that are not currently supported in DCE and/or DCO, then we can request for device support at Device Support site (http://sxwhelpcenter.ecostruxureit.com/devices)
Kind regards
(CID:134693107)
Thank you Jef.
(CID:136152839)
You are most welcome, Ivin
Kind regards
(CID:136152868)
Posted: 2020-07-05 01:38 PM . Last Modified: 2023-10-20 05:09 AM
