Posted: โ2020-07-05 10:48 PM . Last Modified: โ2024-04-03 12:20 AM
We have two stand-alone DCE severs which are polling same devices. I noticed that sometimes the two servers got different data from the same device.
The device is a circuit breaker which communicates with DCE in MODBUS via a power meter gateway. Both servers monitor the breaker state. One server reports the breaker is in OPEN state while another server reports the breakers is in CLOSE state . I tried Request Device Scan and nothing changed.
I tried to deleted the device and add it again, the server then reported correct state.
(CID:149785687)
Same DDF version Files on both Servers?
(CID:149785696)
yes, same DDF version files on both servers.
(CID:149785701)
Posted: โ2020-07-05 10:49 PM . Last Modified: โ2023-10-22 04:08 AM
