Posted: β2020-07-03 11:50 PM . Last Modified: β2024-04-05 04:48 AM
Struxureware datacenter expert sensor history report, we used to create the reports without issue.
However, just one week ago, when I run the saved reports which good for the past, they all went back with error as no data available for the select sensors, no matter choose last 4 hours or last 30 days.
reboot the server one time, but still no lucky.
any thought please?
(CID:125211755)
Posted: β2020-07-03 11:50 PM . Last Modified: β2024-04-05 04:47 AM
BTW, it happened to all sensors, not just one.
(CID:125211761)
Hi Xin,
It's not a known issue, can you verify the date on the server and client are correct? Incorrect dates can cause strange things to happen in reports.
Have you tried creating a new report? Does any data appear?
Does DCE actually show data when you look at the sensors?
Is all your data local or remote repository?
Steve.
(CID:125212210)
Posted: β2020-07-03 11:50 PM . Last Modified: β2023-10-22 04:03 AM
