Posted: 2020-07-03 02:25 PM . Last Modified: 2024-04-08 01:19 AM
Hi all!
I found here such bug: starting with new SxOn version 1.0.3.40 the cooling units of HiRef, for example, NADR/NAUR0341 are detected by the SNMP protocol as Uniflair/Schneider-Electric Aquascroll cooling units. Of course at the same time values of all sensors are wrong.
On demand I can send more detailed information.
Very thanks for the support.
(CID:115345182)
Okay, this is a known issue that we are looking into. Thank you for your input.
Nick
(CID:116361609)
does this happen when discovering via SNMP or Modbus?
Nick
(CID:115345417)
Hi Nicholas St. Pierre,
This happen when I discovered CRAC units via SNMP.
(CID:115345464)
Nick
(CID:116361609)
Ok, I will be glad to help 😀.
(CID:116361613)
Posted: 2020-07-03 02:25 PM . Last Modified: 2023-10-22 03:59 AM
