Posted: 2020-07-03 02:24 PM . Last Modified: 2024-04-08 01:19 AM
Hi all!
In attempt of discovery of the NBRK0450 device in SxOn GW 1.0.3.40 under both protocols (SNMP and NetBotz) I receive two messages in discovery log:
(SNMP) A GENERIC device has been detected.
(NetBotz) A device has been found at this address.
But the number of the found devices remains zero. Why?
Very thanks for the support.
(CID:115345170)
This is likely due to a bug in the way the Gateway handles discovery with multiple protocols at the same time on the same device. There are a few work arounds that can be used before we release a fix:
1) Create a separate discovery entry for just the NetBotz device (no SNMP entries)
OR
2) Disable SNMP on the NetBotz device
Please let us know if this helps. Thanks!
(CID:116365005)
OR
(CID:116365005)
Hi Brian Behbehani,
(CID:116365035)
Dear Brian Behbehani,
As I told in the post , starting from the release of SxOn GW 1.2.0.12, it became possible to perform discovering and monitoring of NetBotz appliance, for example, NetBotz-450. Great work!
The question is solved 😀.
(CID:130091258)
That's great to hear. Thanks for the feedback!
(CID:130091256)
Posted: 2020-07-03 02:24 PM . Last Modified: 2023-10-22 03:08 AM
