Posted: 2020-07-03 10:39 PM . Last Modified: 2024-04-05 05:07 AM
Hello Guys
I cant find StruxureOn App in my App Store
I'm searching by this name "StruxureOn" my location UAE
Musllam
(CID:124523517)
Hello Musllam,
Please see this page for StruxureOn availability: https://struxureon.com/available-in/?nabe=5743821963132928%3A0
The StruxureOn app is currently only available in the US, UK, Irish, Australian and Indian app stores.
Torben
(CID:124523560)
Hello Musllam,
Torben
(CID:124523560)
Hi Musllam.Binhalabi,
But no one and nothing prevents you from downloading and installing on the smartphone StruxureOn app from numerous relevant resources on the Internet 😉. For a real test of StruxureOn digital service is a very good option, which I, for example, have been using for a long time.
Always glad to answer your questions.
(CID:124523628)
Hello
i have already installed StruxureOn App but how can I create an account to login to StruxureOn app. there is no sign up option
(CID:124526592)
Regardless of whether you are using a DCE-server or special free StruxureOn Gateway software, as indicated on page https://struxureon.com/get-started/, you must perform the initial registration and connection (see, for example, section 4 on page https://struxureon.com/download-and-set-up-struxureon-gateway/).
Only after that you can have access on page https://struxureon.com/manage/app/login, where you can manage your StruxureOn gateways, connected devices, users of StruxureOn app and much more.
More details about this and much more can be found on page StruxureOn Help and in the relevant guides: Getting started with StruxureOn guide for administrators and Getting started with StruxureOn guide for users.
(CID:124526619)
Have you solved this problem or not?
With respect.
(CID:125208266)
Posted: 2020-07-03 10:39 PM . Last Modified: 2023-10-22 03:59 AM
