Posted: 2020-07-03 10:38 PM . Last Modified: 2024-04-05 05:08 AM
I have inserted new equipment on two new halls into DCO Lab, but I don't find it into DB postgresql from DCO and I find no way to export or save them.
(CID:124523502)
Hi Raffaele,
As described here: StruxureWare Data Center Operation: Lab
"StruxureWare Data Center Operation: Lab is a separate application you can use to simulate changes to data center models without affecting the model of the actual live environment in the StruxureWare Data Center Operation application."
LAB solutions may be saved as a separate "file" in DCO database, but can only be accessed (opened, modified, saved, etc.) via LAB client.
Kind regards
(CID:124523573)
Hi Raffaele,
Kind regards
(CID:124523573)
Is there any utility for automation export data from DCO Lab?
Thank in advance for your help
(CID:124523695)
Hi Raffaele,
Sorry, no - currently it is not possible (not supported) to export or import a StruxureWare Lab solution.
I would also like to mention that the usual DCO backup contains the Lab solution(s) as well.
Kind regards
(CID:124523718)
Hi Jef Faridi,
I've tried to find in the file dump DB and other file from *tar.gz of backup our DCO but I can't find data of DCO Lab, are there any configuration to modify for save DCO lab?
(CID:124524302)
Posted: 2020-07-03 10:38 PM . Last Modified: 2024-04-05 05:07 AM
Hi Raffaele,
Please let me clarify: DCO backup file (*.tar.gz) is a backup of your setup (both DCO and possible LAB solutions). This backup file can be used for safe-keeping and can also be used to restore the whole setup (in case if needed). So both your LAB solutions and your actual DCO setup is included in the usual backup (but not as a separate/individual file).
Kind regards
(CID:124524324)
Posted: 2020-07-03 10:39 PM . Last Modified: 2023-10-22 04:00 AM
