Schneider Power Meter PM8000 SNMP DDF issues
  • EcoStruxure IT forum
  • Schneider Power Meter PM8000 SNMP DDF issues
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 09:50 PM . Last Modified: ‎2024-04-03 12:40 AM
876
Hi
We have seen some issues with PM8000 SNMP DDF:
1-Data Center Exper value " Label" don't show the device name , other values are correct.
2-Data Center Expert  sensor value "Power factor" is negative but  the device power factor value is positive
3- It is posible to add  power quality values to the DDF:
THD Voltage
V1 THD 3s (%)
V2 THD 3s (%)
V3 THD 3s (%)
THD Current
I1 THD 3s (%)
I2 THD 3s (%)
I3 THD 3s (%)
I4 THD 3s (%)
I1 K   Factor
I2 K   Factor
I3 K   Factor
I4 K   Factor
I1 Crest   Factor
I2 Crest   Factor
I3 Crest   Factor
I4 Crest   Factor
 Thanks in advance for the help
Regards
(CID:148343468)
  • DDF
876
Hi Sergio,
Thanks for reporting this.  Would you mind reporting this issue on the DDF page?  You can find it here:  DDF download.  It forces you to first search, but as soon as you do, you can click the "Request" button.  This will create a ticket for the DDF team.
Jake
(CID:148343845)
Hi Jake, thanks for the answer , I proceed as you indicate.
Regards
(CID:148343961)
Posted: ‎2020-07-05 09:50 PM . Last Modified: ‎2023-10-22 03:52 AM
