DCO 8.2.7 Network Utilization
  • EcoStruxure IT forum
  • DCO 8.2.7 Network Utilization
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 09:50 PM . Last Modified: ‎2024-04-03 12:40 AM
1005
Dears,
While adding the network routing (ports connection) from switches ports to patch panels ports & field equipment (UPS, NetBotz, CRAH units, Servers).
The network utilization percentage displayed on the pie chart considered only the ports connected to field equipment and neglected patch panels connections (considered them not-utilized ports).
Then, How to overcome this issue? How to consider all switches ports connection (even connected to field device or patch panel) in network utilization percentage?
Note: The patch panels rear side connected to other systems devices (Cameras, Control panels, Chillers , ... etc.).
Ahmed Ashraf
(CID:148343654)
  • Data Center Operation
Replies 5
Posted: ‎2020-07-05 09:51 PM . Last Modified: ‎2024-04-03 12:40 AM
1005
Hi Ahmed,
Patch panels (similar to cables) are not included in the Capacity Overview calculations. Network ports in layer 2 & 3 network equipment (such as server/switch) are included in the capacity history KPIs.
Kind regards
(CID:148343663)
Dear Greg,
I understand what you say, But there is no cameras (as example) in DCO
Then how to utilize all switches ports of cameras to be considered in Network utilization calculations.
Ahmed
(CID:148344011)
Hi Ahmed,
As a work around I would try customizing/using a switch device and call it "camera switch" and then configure its network ports and set its power settings to zero, without power inlets (to not include in power capacity calculations).
Kind regards
(CID:148344014)
Dear Jef,
OK, i did this work around and i'll check the network utilization update tomorrow and back to you with updates
Thanks for your support
Ahmed Ashraf
(CID:148344097)
Posted: ‎2020-07-05 09:51 PM . Last Modified: ‎2023-10-22 01:33 AM
