Posted: β2020-07-05 09:50 PM . Last Modified: β2024-04-03 12:40 AM
Hi
We have seen some issues with PM8000 SNMP DDF:
1-Data Center Exper value " Label" don't show the device name , other values are correct.
2-Data Center Expert sensor value "Power factor" is negative but the device power factor value is positive
3- It is posible to add power quality values to the DDF:
THD Voltage
V1 THD 3s (%) |
V2 THD 3s (%) |
V3 THD 3s (%) |
THD Current |
I1 THD 3s (%) |
I2 THD 3s (%) |
I3 THD 3s (%) |
I4 THD 3s (%) |
I1 K Factor |
I2 K Factor |
I3 K Factor |
I4 K Factor |
I1 Crest Factor |
I2 Crest Factor |
I3 Crest Factor |
I4 Crest Factor |
Thanks in advance for the help
(CID:148343468)
Hi Sergio,
Thanks for reporting this. Would you mind reporting this issue on the DDF page? You can find it here: DDF download. It forces you to first search, but as soon as you do, you can click the "Request" button. This will create a ticket for the DDF team.
Jake
(CID:148343845)
Hi Jake, thanks for the answer , I proceed as you indicate.
(CID:148343961)
Posted: β2020-07-05 09:50 PM . Last Modified: β2023-10-22 03:52 AM
