SMTP/Gmail = SMTP configuration error
  • EcoStruxure IT forum
  • SMTP/Gmail = SMTP configuration error
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 11:42 PM . Last Modified: ‎2024-04-05 04:50 AM
3003
Greetings.
I'm having problems to configure Notifications->E-mail in NetBotz 250. All the time i get "SMTP configuration error".
I'm using Gmail: smtp.gmail.com
Hope to hear from you ASAP and thanks in advance.
(CID:125210779)
  • NetBotz
3001
Hi Karimo,
There's a pretty good k-base that walks you through NMC based products like the NetBotz 250 working with things like gmail. You can find k-base FA164769 here.
Steve.
(CID:125210795)
Replies 4
3002
Hi Karimo,
Steve.
(CID:125210795)
Hi Steven.
I've tried all the steps but unfortunately the problem was not solved.
 On DNS->Test = Pass!
E-mail Server Settings:
From Address: xxxx@gmail.com
SMTP Server: smtp.gmail.com
Port: 25
Authentication = Enabled
User Name: xxxx@gmail.com
Password: xxxx
Confirm Password: xxxx
Use SSL/TLS: If Supported
E-mail Recipient:
Generation = Enabled
To Address: xxxx@gmail.com
Server: Custom
Custom E-mail Server Settings: *same as above.
*Allowing less secure apps to access your account/Gmail = Active
But still get = SMTP configuration error.
Maybe i'm missing something?
(CID:125210826)
Hi Karimo,
Can you review the link below. It may help you.
https://support.google.com/a/answer/176600?hl=en
Regards
(CID:125211070)
Posted: ‎2020-07-03 11:43 PM . Last Modified: ‎2023-10-22 03:48 AM
