Posted: 2020-07-03 11:43 PM . Last Modified: 2024-04-05 04:50 AM
Greetings,
While using the Infastruxure Designer 9, I wanted to open the solution in 3D view,but the program crashes and closed.
Is there a solution for this issue?
(CID:125210812)
Hi Luigimar Perez, thanks for posting. Sorry to hear you're having trouble with the 3D view. Let's hope you find your answer here.
Kind regards Ditte
(CID:125212670)
Hi Luigimar,
ISX Designer offers support via another channel (not in this Community), they can be contacted using one of the following method:
Kind regards
(CID:125212810)
Posted: 2020-07-03 11:43 PM . Last Modified: 2023-10-22 02:52 AM
