Some seosor missing when try to add to DCE web dashboard
  • Some seosor missing when try to add to DCE web dashboard
129
72
Posted: ‎2020-07-03 11:43 PM . Last Modified: ‎2024-04-05 04:50 AM
1035
Hi Team ,
We have 5 power meter under one EGX gateway on DCE , we tried to add some sensor into DCE
web dashboard and can't found some value in the sensor list , one power meter include 44 sensor
value , when we search for the gateway , there should be 220 sensor value but only 100 sensor value ,
that's cause some sensor like voltage B-C in slave1 we can't added to the dashboard .
Can someone advice what's problem on this ?
Best Regards
(CID:125210918)
Replies 4
Hi, Chu Li Wei,
Thanks for posting in help.se-dmaas.com.
We suggest you search the sensor name (in this case "Voltage B-C") in the search field, instead of IP address, and add the relevant sensor thereon.
Navaneethan.R
(CID:125210929)
Hi Chu Li Wei,
Have you solved your problem or not?
With respect.
(CID:126159041)
Posted: ‎2020-07-03 11:44 PM . Last Modified: ‎2024-04-05 04:50 AM
I have the same problem.
And Iuse IP  can't see  anything.
(CID:128762323)
Posted: ‎2020-07-03 11:44 PM . Last Modified: ‎2023-10-22 03:58 AM
