Posted: ‎2020-07-03 10:22 AM . Last Modified: ‎2024-04-08 02:35 AM
Is Restful API able to use the patch request to replace custom properties?
(CID:110790429)
No - custom properties can only be updated through the SOAP API.
StruxureWare Data Center Operation Web Service API
(CID:110790494)
Hi
Note from 8.1 you can update the custom properties via the asset service - not via patch requests - but as resources.
Ulrik
(CID:118000975)
Posted: ‎2020-07-03 10:22 AM . Last Modified: ‎2023-10-22 03:41 AM
