How to restore from backup StruxureOn Gateway?
  • EcoStruxure IT forum
  • How to restore from backup StruxureOn Gateway?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 10:23 AM . Last Modified: ‎2024-04-08 02:34 AM
718
Hi all!
My question: at the StruxureOn GW 1.0.2.9 web-interface there is a backup option, but for some reason there is no restore option from a backup copy :-/. How it is possible to use already created backup copy for restore StruxureOn GW server?
Very thanks for the support.
(CID:110790577)
  • DCIM Support
718
While backups are performed through the StruxureOn Gateway UI, the restore functionality happens outside of the product via a CLI tool run from a Windows command prompt.
If you browse your Gateway server and look in the Gateway install path (Default path is: C:\Program Files\StruxureOn Gateway) you will find a directory called restore. This is where the Gateway restore utilities reside.
To restore from a previously created backup:
  • Open a command prompt on your Gateway server
  • Navigate to the restore directory
  • Execute the apolloRestore.bat script
    • With no arguments passed to the script, you will get help information printed to the screen including examples on how to execute the restore process. I've attached a screen shot of the help output.
  • The utility will search for backups at the location you specify and will prompt you to choose the correct backup
  • After a series of confirmations, the restore process will begin.
(CID:111414635)
Replies 4
Hi spezialist, thanks for posting. Lets see who can be of assistance here. @community any ideas?
Kind regards Ditte
(CID:110791525)
719
(CID:111414635)
Hi Derek Robson,
Very thanks for the detailed and good answer. I will surely try it in practice.
Thanks.
(CID:111414656)
Posted: ‎2020-07-03 10:23 AM . Last Modified: ‎2023-10-22 02:34 AM
