Posted: 2020-07-02 09:36 AM . Last Modified: 2024-04-10 01:10 AM
In Building Operations Suite, I am trying to run "Workstation for projects 1.5" and the login screen is asking me for a server. What server is it asking for? Enterprise Server, Automation server, local?
Do you need the "Project Configuration Server" to be installed in order to run "WorkStation for Projects"? If so, is it an additional software which needs to be purchased?
J
(CID:93193571)
Posted: 2020-07-02 09:37 AM . Last Modified: 2024-04-10 01:10 AM
Hi John,
Have you seen this article related to your question? https://community.se.com/t5/Building-Automation-Knowledge/Error-quot-Invalid-Server-Type-quot-when-a...
From what I read the "Project Configuration Server" must be installed.
(CID:93193644)
(CID:93193707)
Posted: 2020-07-02 09:37 AM . Last Modified: 2023-10-31 11:31 PM
