Add Device/Meter type in PME
  • Add Device/Meter type in PME
129
72
Posted: ‎2020-07-02 09:35 AM . Last Modified: ‎2024-04-10 01:10 AM
2039
How do I add a new device type to PME? I have a "Veris H8035/H8036 Power Transducer" and I need a device file for PME to interpret the data.
I am asking for something similar to a DDF in DCE.
J
(CID:93193521)
  • power monitoring expert
Replies 4
2039
John, This device type should be native to your PME software. It is likely listed in Management Console as an "Enercept" meter.
(CID:93193575)
Posted: ‎2020-07-02 09:36 AM . Last Modified: ‎2024-04-10 01:10 AM
Kevin, There isn't anything listed in the device type called "Enercept". Any other ideas or names for it?
(CID:93193577)
Sorry John, there is in fact an installer, and you should be able to download it from the following BOX location:
https://schneider-electric.app.box.com/s/6x519y1kkhmke8m1qusw
Description:
This is a Standard Edition Driver for PME 7.2.2.  The package contains
 (1) Installation file (.exe)
 (2) Release Notes document (.pdf)
 (3) Mapping Details (.xlsx)
Improvements over the current CE driver:
- Updated register labels to support PME factory reports
- Added Resets (Energy, Demand)
- Supports LE upgrade (i.e. users using the CE driver can upgrade to this new driver without losing existing logs)
- Supports both Basic and Enhanced variants
Content Creator:
Technical Support:
This driver is supported through standard support channels.
Download:
Download package available on Box at the following location:
https://schneider-electric.box.com/s/6x519y1kkhmke8m1qusw
(CID:93193579)
Posted: ‎2020-07-02 09:36 AM . Last Modified: ‎2023-10-31 10:13 PM
