Post to Data Center Expert in Netbotz
  • Post to Data Center Expert in Netbotz
129
72
Posted: ‎2020-07-04 02:09 AM . Last Modified: ‎2024-04-05 03:55 AM
863
Normally when I discover a netbotz device i see the following in advanced view:-
On some systems I am seeing just the Surveillance in "Type of post" or nothing at all. EDIT: by nothing at all I mean the "Post to Data Center Expert" icon is not available in Netbotz Advanced View...
I figured out how to get surveillance back, but not Alerts or Periodic report.
What does "periodic report" do?  (with regards to DCE)
How do I get it back in Netbotz?
How do I get "alert" back?
The DCE server is on version 7.4.3 and most of the Netbotz are 4.5.x...
Regards
(CID:126179348)
  • NetBotz
Replies 5
863
Dear Garry Priestland,
From you question:
That's right, it should be, if you have nothing configured in the Advanced View POST-only mode Configuration window in the menu Tools -> Advanced -> Advanced View POST-only mode... Check it out, and if there's nothing there, add your DCE-server there. After that, you will have an icon that you mention.
See above.
I hope this helps you.
Was glad to answer questions.
(CID:126179625)
Thanks for the response.
I did figure out how to get the icon back and how to get Surveillance and Alerts.  The Periodic Report entry is still missing.
What is more concerning is why so many of the Netbotz on this server are different.  As far as I know there have been no manual changes made to the Netbotz at all, so I don't understand the inconsistency.
I guess I could delete the Netbotz from DCE and Discover it again, but I have dozens of them and don't want to do that for each one of them...
(CID:126179750)
In the APC Advanced View software, click the Configuration -> Periodic Reports button. In the Periodic Reports Configuration window that opens, check or add the Periodic HTTP Report you need to.
With respect.
(CID:126179815)
Have you solved your issue or not?
With respect.
(CID:126183365)
Posted: ‎2020-07-04 02:09 AM . Last Modified: ‎2023-10-22 03:35 AM
