Posted: β2020-07-04 09:37 PM . Last Modified: β2024-04-04 03:36 AM
How accurate is PDU metering supposed to be?
I have two AP7822B's where the total current measured is not the sum of each bank,
or is the difference the management interface power drain?
Other model PDU's totals do add up.
(CID:133370258)
Hi Mark,
Good day!
This metered rack PDU has an accuracy of up to +/- (3% + 1 digit). A table which describes its functional metering specifications can be seen from the link below:
https://www.schneider-electric.us/en/faqs/FA156074/
I hope this answers your question.
Kind regards,
Justine
(CID:133370267)
So just it's addition is the problem then π
(CID:133370283)
Posted: β2020-07-04 09:38 PM . Last Modified: β2024-04-04 03:36 AM
As long as that it is within the margin of error, then it should not be a problem. Thanks Mark.
(CID:133370292)
Dear Mark,
Tell us, please, have you solved this question or not?
With respect.
(CID:134026538)
Posted: β2020-07-04 09:38 PM . Last Modified: β2023-10-22 03:30 AM
