How do i generate consolidated reports watts and Kilowatts power
  • How do i generate consolidated reports watts and Kilowatts power
129
72
Posted: ‎2020-07-04 09:37 PM . Last Modified: ‎2024-04-04 03:36 AM
963
Hi Members,
I have virtual sensors of Total Power Watts & Total Power Kilowatts, so i want to have  a new virtual sensor of both  total values.Kindly advise solution for this to have a consolidated report.
(CID:133370187)
Dear Shaik Mahboob Ali,
From your question:
...so i want to have  a new virtual sensor of both  total values.
As far as I know, unfortunately this is not possible in the current version of DCE-7.x.
I can only recommend you to use the Feature requests option here on the EcoStruxure IT. And it is possible in the future version of DCE-8.x this feature will be implemented.
With respect.
P.S.: from my own experience: I had the same problem, so I just started using virtual sensors with only one unit of measure, for example, kW. To do this, I needed to supplement several DDF-files with the appropriate sensors to bring all my devices to a common unit of measure.
(CID:133370211)
From your question:
With respect.
(CID:133370211)
Posted: ‎2020-07-04 09:37 PM . Last Modified: ‎2023-10-22 02:22 AM
