Posted: β2020-07-03 02:05 AM . Last Modified: β2024-04-09 12:24 AM
I use firmware v.4.5.1 and system send snmp-trap with OID 1.3.6.1.4.1.5528.100.10.2.0.10, 1.3.6.1.4.1.5528.100.10.2.32, 1.3.6.1.4.1.5528.100.10.2.33 etc.
In Last version MIB NETBOTZ410 (LAST-UPDATED "201104120000Z") its traps are missing.
Where i can get actual version MIB or how version firmware i can use with MIB 410?
(CID:105471519)
Posted: β2020-07-03 02:05 AM . Last Modified: β2024-04-09 12:23 AM
Hi Victor,
There is a new version of the NetBotz MIB being created and it should be available soon. I had specifically seen issues with the OIDs you mentioned and noted that in an enhancement request. These OIDs should be in the next revision due out soon. When available, the NetBotz MIB should be on the APC software downloads page:
(CID:105471543)
Hi Victor!
Latest version is 417.
You can find it on apc.com or in attachment.
(CID:105471522)
Hi Valentin! It's MIB for APC UPS. NetBotz traps are missing.
(CID:105471539)
Hi Victor,
(CID:105471543)
Hi Victor, If you would like an early evaluation of the new NetBotz410 MIB, I'm attaching it here. It is running through our final testing process right now, and will be available to download from the APC website in a few weeks. But I thought I'd offer you the opportunity to try it out now and make sure it solves your issue. -Scott
(CID:105474375)
Posted: β2020-07-03 02:06 AM . Last Modified: β2023-10-31 11:27 PM
