Posted: 2020-07-05 01:35 PM . Last Modified: 2024-04-04 12:27 AM
Hi team,
Could you please prove as with possible road map about physical network connection support in Rest API.
We are looking for a way to manage export (and import) patch panel and equipment network connections threw the Rest API, without ETL engine.
Thank you in advance.
(CID:134692004)
Hi Dmitry,
I don't think we have road map for that - if you wish I can capture a feature request for you/customer. However, as you've mentioned, either manual configuration or integration via ETL (specially for large setups) would be an option. Customized ETL integration can also be ordered at CSP (Custom Specific Project) team. For details/price, Lasse Simonsen can be contacted.
Kind regards
(CID:134692596)
Posted: 2020-07-05 01:35 PM . Last Modified: 2023-10-22 03:26 AM
