Posted: 2020-07-03 10:20 AM . Last Modified: 2024-04-08 02:35 AM
Transfer of firmware for wireless sensors never starts over Zigbee wireless.
Updates for Coordinator/Router and Pod 180 only transferred when they were configured as a coordinator on USB port of Netbotz host (with the other device being configured at that time on an AC supply as a router.
Apply Firmware update button is always greyed out even with no end devices configured.
System has been left well over 12 hours.
(CID:110020423)
Hi Pete, we had the same issue with our NBWS100H and HBWS100T sensor Pods at firmware level 1.0.0. Its a known bug with the firmware. We had to send our sensors back for replacement sensors that were upgraded to 1.0.4. Contact DCIM Tech support and have them reference case# 28884199.
(CID:110020431)
Pete, my company email is barry.Patterson@seattlechildrens.org if you would like to discuss offline.
(CID:110791506)
Hi Pete, Barry,
Don't reference that case number for a new issue. That case number is specific to Barry's issue and tech support will need to validate whatever issue you may have with these sensors. They will give you a new case number should you contact them.
Support may be able to perform an upgrade in a different way with you and the sensors may not need to be replaced.
Steve
(CID:110020438)
Posted: 2020-07-03 10:20 AM . Last Modified: 2023-10-22 03:25 AM
