Warning: Purge Warning - Nearing High Water Mark of 90 currently using
  • EcoStruxure IT forum
  • Warning: Purge Warning - Nearing High Water Mark of 90 currently using
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 10:21 AM . Last Modified: ‎2024-04-08 02:35 AM
1478
Hi.  Can anyone tell me what this means and if this is a future problem how can I fix it?
Message from DC Expert:
Warning: Purge Warning - Nearing High Water Mark of 90 currently using 80% of total capacity
Thanks and regards
(CID:110020732)
1479
Sæþór,
That error message is a system level event from StruxureWare Data Center Expert warning that it is going to start purging old data soon to free up storage space.  You can see your storage settings and purge settings within the Data Center Expert Client under: System Menu > Server Administration Settings > Storage Settings.
Cory
(CID:110020767)
Replies 4
1480
Sæþór,
Cory
(CID:110020767)
Thanks Cory.
Excellent response time. 🐵
(CID:110791512)
You're welcome.
(CID:110791514)
Posted: ‎2020-07-03 10:21 AM . Last Modified: ‎2023-10-22 04:16 AM
