Netbotz sensors accuracy
  • EcoStruxure IT forum
  • Netbotz sensors accuracy
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 01:22 AM . Last Modified: ‎2024-04-09 12:37 AM
1200
Hi Team!
Is there any official info about Netbotz temperature and humidity sensors accuracy?
There is no info on apc.com, working range only.
I met info about +/- 2 degrees somewhere, but I'm not sure...
Any help will be appreciated.
(CID:105469530)
  • NetBotz
1200
Hi Valentin,
                  kindly see the below k-base link for more information.
K-base ID: FA158170
http://www.apc.com/site/support/us/en/faq/?page=content&country=ITB〈=en&locale=en_US&id=FA158170&red...
Temperature sensor Accuracy: + or – 1.8F + or – 1C
Humidity sensor Accuracy: + or – 5% RH
Dew Point sensor Accuracy: + or - 2 degrees F
Airflow sensor Accuracy: + or – 50 fpm .
BR,
Rana Ajmal
(CID:105469536)
Replies 8
1201
Hi Valentin,
K-base ID: FA158170
BR,
Rana Ajmal
(CID:105469536)
Thank you Rana! It's for v2 internal sensors. Will it be valid for AP9335?
(CID:105469539)
1200
Hi Valentin,
The info is sort of spread out. For the older version 2 NetBotz, k-base FA158170 has some info. In most cases for version 3 sensors, there are accuracy statements in the install or user guide. For instance for the AP9335T:
http://www.apcmedia.com/salestools/ASTE-6Z5QD2/ASTE-6Z5QD2_R0_EN.pdf?sdirect=true
Temperature accuracy ±3ºF (±2ºC), from 32 to 104ºF (0 to 40ºC)
For the NBWS100H, It's on the product page listed under range:
http://www.apc.com/shop/us/en/products/NetBotz-Wireless-Temperature-Humidity-Sensor/P-NBWS100H
Sensor Humidity Range
±3% RH from 11% to 89% RH %
I know it can be difficult to find. If you have a specific sensor you can't find info on, we can see if we can find it for you. I know the whole site is being changed around.
Steve
(CID:105469540)
Thank you Steve!
(CID:105469541)
Welcome 😃
(CID:105469542)
It's not enough clear to me to find sensors specification in docs for discontinued expansion module 😄
(CID:105469543)
Hi Valentin, If you're referring to the sensor pod 120s, the accuracy would be the same as the stand-alone sensors listed in the k-base. If you're referring to something else, can you please specify? Steve
(CID:105469544)
Posted: ‎2020-07-03 01:23 AM . Last Modified: ‎2023-10-31 11:26 PM
