Posted: 2020-07-03 01:23 AM . Last Modified: 2024-04-09 12:37 AM
Hi All,
I have created a few dashboard on PME, then i will use their URL link for integrate to Portal. However, i choise different pages, i see same URL link so this i can not link any specific dashboard page. Do you know how can get the specific URL?
Regards
Kerem
(CID:105469552)
Hi Kerem,
As you might know, the supported portlets and there description is listed here:
https://dcimsupport.apc.com/display/public/Portal/Portlet+data+sources
Concerning the URL question, I guess one way might be to bookmark the "page" and then check its properties - the bookmark 'location' usually contains the url info. Or perhaps and in general viewing the page html source code (ex. IE, View > Source) that might also contain some url info.
However, it should be noted that out of the box, the supported portlets are included in Portal. You might be able to display your certain web page(s) via IFrame in Portal (Add portlets > Sample > IFrame).
Note: IFrame is disabled for DCO 7.5.
Hope this helps.
Kind regards
(CID:105470324)
Hi kerem.yilmaz, thank you for posting! Let's see who can be of assistance here. @community - any ideas? Best, Stine
(CID:105469948)
Hi Kerem,
Hope this helps.
Kind regards
(CID:105470324)
Posted: 2020-07-03 01:23 AM . Last Modified: 2023-10-31 11:29 PM
