Posted: 2020-07-03 01:21 AM . Last Modified: 2024-04-09 12:38 AM
Hi Team,
I am new to StruxureWare product.
I was looking for the articles in the link https://dcimsupport.apc.com/display/public/SWDCDOC/Specifications+and++Guidelines+for+Server+Install...
I see some products like StruxureWare Portal supports deployment in Windows platform.
I would like to know if StruxureWare data center application itself is available on Windows or is it limited to Linux only ?
(CID:105469524)
HI Gautam!
At the moment DCO and DCE products are available only as "prefabricated" linux-based distributives.
As I know there were some plans to make it standalone applications for different platforms, but I dont have any info to proof it.
Maybe we will see it in one of future releases.
(CID:105469528)
Hi Kozlov,
Thank you for the reply, Is the StruxureWare data center supported in Linux Cent OS Only or can it be installed on Red Hat Linux and other Linux flavours as well ? Is there any recommendation on this ?
Also is StruxureWare data center only supported on 64Bit OS or does it also work on 32Bit OS as well ?
(CID:105469899)
Posted: 2020-07-03 01:21 AM . Last Modified: 2024-04-09 12:37 AM
Hi Kozlov,
Any update ?
(CID:105469898)
Posted: 2020-07-03 01:21 AM . Last Modified: 2023-10-31 10:19 PM
